Hi All,
is there a way that I can split the slab. part of my slab's top surface level is 100mm above the level. I dont want to delete the slab and recreate it as there are now other members in place such as beams and walls
Thanks in advance
Managed to find under modify floor,
added split line and given elevation to four points of slab to lift 100mm above level. it worked well
You can click the slab then edit boundary draw a line where you want to split the slab, then draw another line (offset 1/8" from the first) then split the upper and lower boundary of the slab and clean up the corners so its two separate slabs without any intersecting lines (control joint).Ive found this method very useful several times.
