Split Segment Section Option Greyed Out
I thought I trying to do something trivial, something I've been many times before, and I wanted to adjust one part of a section cut a few feet. Then, for whatever reason in my REVIT 2019.2 file, when the section callout is selected the option to split it is greyed out in the "Modify Tab".
I assumed a quick search would reveal and easy answer and I couldn't find any relevant solution. I tried pinning unpinning, reversing the section, trying different types of section and callouts. New sections do not show this behavior and the split segment option is available as normal.
We're really only changing the left 1/6th of an already polished and annotated section so I really rather not redo everything so near the deadline. Does anyone have a solution to this?
Split isn't available for a callout.
...are you meaning that you want to adjust the crop size?
I see.
I thought the OP was talking Split not Break.  Maybe I misread.  Still working on that Vulcan Mind Meld thing you got going on.
