Revit LT split section which cuts through a window, the window masks the drawing behind the window which is not in the split section view. How do you override this behaviour?
As it reads:
As it should read (window temporarily hidden) although you see it as if the window were not there, ie cladding behind on the left hand side of the split line.
Cut line is the inverted L shaped line after Laundry, window masking is above the word demolish.....
