Split Schedules - Add a new additional split page
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
RMITDAMIEN
298 Aufrufe, 3 Antworten
I have setup split schedules across two sheets. We have finished the schedule entries and now require 3 sheets to fit the contents. Hoping there is something simple I am missing to add the third split / sheet? I have looked at all right click menus on the parent and child views, the contextual ribbon, not having much luck looking for something that says "add new split sheet".  wishful thinking?
(Really hoping the answer isn't having to delete the existing split schedules and recreate them again, and nominate 3 sheets instead.)
3 ANTWORTEN 3
Nachricht 2 von 4
mhiserZFHXS
als Antwort auf: RMITDAMIEN
Click that little zig-zag on the sheet view of the schedule. You can then drag the schedule from this sheet to another in the project browser.
Nachricht 3 von 4
RMITDAMIEN
Thanks for the response, that worked. To close this out i'll add my experience from the solution.
Once you click the break, it dumps the break view to the side. What you may not notice is it creates a new view in the project browser- you'll notice it updates from 2/2 to 3/3 in this example. You can then drag the view from the project browser to the new sheet you have created.
Unfortunately though, you'll need to manually remove the excess break view from the sheet it was created on by right clicking on the new view in the sheet and selecting 'remove from sheet'.
You could do this in reverse by duplicating the 2/2 sheet and then creating the break, either way, its a clunky manual step to clean things up, move things around.
Hopefully future development makes this more straight forward. Add a right click menu option "Add New Split & Place".
Nachricht 4 von 4
mhiserZFHXS
@RMITDAMIEN
No. Do not duplicate the original schedule and then do this. All you have to do is move the new split section to a new sheet. Duplicating the schedule will mean those break lines will no longer correlate with one another. If you stretch the schedule on one sheet, its not going to reduce it on the other, leading to potential duplicates, or worse, items being left off the schedule.
