split schedule on multiple Revit sheets - a methood that worked and now fails
danezeq
Message 1 of 8
danezeq
I've splitted a long schedule according to this methood:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
it worked fine for a while and suddenly it stopped working, it gives me output of an empty page(s)
i dont know what i have been changed in the project, what steps should i take to check it or just "reset" the schedule and do it from scratch? having said that, how do i join splited schedule? there is a button just for split, not for join them back.
Replies (7)
Message 2 of 8
Ilic.Andrej
To reset the schedule, grab the "move" handle and just drag it to the left column.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
Are the Sheets empty?
Message 4 of 8
danezeq
Great! i would never guess that by myself.
Message 5 of 8
danezeq
What do you mean? ofcourse not! they are as they where in it worked.
Message 6 of 8
Well, if Revit isn't printing what's on the Sheet, then that is strange.  In that case, I would suspect the Printer/Settings; not Revit.
Message 7 of 8
danezeq
at the end i used the "split by filters" way. this way i dont FIGHT with that printer settings.
Message 8 of 8
The printer settings are 100%, no margin offset, and correct page size. The out of page part of the schedule should be on the right and above the bottom of the title block. That is it.
