Split Landing with Riser
Message 1 of 11
Hi Folks,
I'm brushing up on Revit skills for a new job I am starting in a couple of weeks by going over the course work I did college.  However, I have noticed that I am unable to add a riser to a landing in order to increase the number of steps in a staircase in a residential building.  Prior to Revit 2019 you were able to just select the stair, edit sketch and then add a riser to the landing.  I'm lost on how to do this since the newer iterations of Revit have changed the way stairs are added.  Any help would be greatly appreciated.
Steve
Replies (10)
Message 2 of 11
Component Stairs vs. Sketch-Based Stairs?  You can convert a Component Stair to a Sketch-Based one. Edit the Stairs, select the run,  and you will see the option to convert on the Contextual Tab.
...I think Component Stairs were first introduced in 2017.  FWIW.
Message 3 of 11
You can create a component stair and convert runs and landings to sketches.  However, sketches are mostly are for stairs with odd shapes.  There maybe a better way if you only need to add a riser/step.  Share a picture or a file of what you need to achieve and we will see.
Message 4 of 11
Here is a screen shot of the landing I am trying to add a riser to and also the picture of how it's supposed to look.
I can't seem add a riser when I edit the stairs/landing.  Any help would be greatly appreciated.
Message 5 of 11
Those instructions under Modify are pretty much what I said to do in my first post.  Pick the Stair and then pick Edit Sketch. Where are you running into a problem?  Are you editing a Component Stair? Well, you need to "Convert" to a Sketched-Based Stair first -- as I explained in my post above.
Message 6 of 11
I'm unable to Edit Sketch, instead I can Edit Stair.  I convert the landing into sketch-based and it won't let me add the riser.  I'll include the file for your review.  Please let me know what you think.  Thanks
Message 7 of 11
The issue you are having is that you are following the instructions to create and modify a sketch-based stair, but you have created a Component Stair - a completely different animal.  I'm betting the tutorial you are following is for Revit 2016 - before there was a Component Stair.   To follow this tutorial, you need the redo stairs using sketch tools, manually defining the Boundaries and Risers of both flights and landing.
Message 8 of 11
eric_elftman
I'm in the same boat.  I watched 3 different tutorials on how to to get that spilt stair on the landing.  Some how I keep missing how to get the second half of the landing to raise and reconnect to the second half of the stair case.
Message 9 of 11
turnerjayt
Observer
Observer
Re "SPLIT LANDING WITH RISER"
Hi
messaged you a couple weeks ago about this discussion you were in on "SPLIT LANDING WITH RISER"
Were you able to find a minute to explain how you did it?
J
Message 10 of 11
Can you post some screenshots of exactly what you want?  Photos or sketches will work.
Message 11 of 11
turnerjayt
Observer
Observer
Hi.
Sorry for the delay.
Been very busy with new multiplex plans and we are just transitioning into
Revit from Autocad.
I would be grateful if you could share stepbystep on how to build this
specific SPLITLANDING stair. We see this is an issue with REVIT 2024 and
alot of people have the same problem.
We use this style for our laneways all the time since it is such a limited
footprint, every inch counts.
Thank you so much.
Jason
