Split face paint tool on a column
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
906 Aufrufe, 2 Antworten
I have a column that I have used a split face + paint tool command on as the column changes color halfway up. However, this is now appearing on my elevations, the painted bit of the column. is there a way to get around this? Can you "hide" the color that you painted the face with in elevations but show it in colored elevations?
Ps. as the height of the split face changes around the building I cannot give it a parameter in the family.
Cheers!
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
Hi
Change the Properties of Material to get it right in Elevation and coloured.
Fix
1. Surface pattern
2. Colour
Corsten
Building Designer
Tags (1)
Nachricht 3 von 3
als Antwort auf: Corsten.Au
thanks Ganesh. I figured it out right after I posted it, haha, but I just went into Override element and changed it there.
Cheers!
