Working on a healthcare project where we have varying colorways of the same rubber tile. I'm using the split face command to apply the different materials. There is an instance where 2 materials intersect. I'm trying to figure a work around so I can still use split face, and not have the split face lines intersect. Any ideas?
Can you point out which overlapping lines you are referring to?
@Marli_Swart wrote:Working on a healthcare project where we have varying colorways of the same rubber tile. I'm using the split face command to apply the different materials. There is an instance where 2 materials intersect. I'm trying to figure a work around so I can still use split face, and not have the split face lines intersect. Any ideas?
Use the Linework tool and make the Split Face linework Invisible.
