I am using Revit 2024 and creating a "rainbow" stripe like flooring design. I am using the split face and paint tool to create it. However, after doing this so many times now, for some reason when I start a new split face on the floor, Revit paints over everything with my last previously used Paint material.
I have closed out of the program twice and started the project up again thinking it would help and no luck. Any help? I saw someone with this same problem back in 2017....
I lniked what it looks like before and after starting a new split face so you can see how it takes over the entire floor material. Mind you, the flooring already is painted and set to a certain material that is NOT that magenta color on the second screen grab.
Is there anyway you can share the 2017 model?
