https://forum.dynamobim.com/t/split-a-wall-along-the-length/64790?u=amarkonathala
Hi ,
I want to split a wall along the length at a distance of 2’ each split can this done by dynamo,
Pleas help me out if it works with dynamo
Tnq
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Usually, one uses dynamo to do things which are not that simple to do in Revit...What you are asking for can simply be done using an Arrayed Void in Revit ... no dynamo required.
Thank u for the reply,,
I have to fill the void again with different type wall
This makes me some wat crazy
Well it is not clear what you are modeling. The original post and the image therein gave me the impression that you to cut off 2' segments of the wall...Now I see that you want to have 2 alternating 2' segments of wall types? is that right?
Try using a curtain wall without mullion...set the vertical grid to 2' and replace the panels with Basic wall types
In dynamo lots of things are possible but you will need to define precisely what you are doing and what would you like to achieve...Just a simple statement I want to split wall @ 2' isn't enough. Example: Here is a node that can split/divide wall parts for instance...place ref planes at any interval you wish and the node will split it at those intervals then you can set a different material for each
Hi
I wanted to model the road side kerbs!
I checked as u like did but iam getting the error while running the script
error
can u please clarify why iam getting this!
You need to convert the wall to Parts first... see steps below GIF
There are other routines you could use in dynamo but that would require more inputs and more nodes such as
I still believe using a curtain wall option shown in the first reply is an easier option for you. Especially if you are not really good with visual programing (aka dynamo)...
