I am working on The Theme Building, LAX airport. I drew this in Revit Architecture Template by using Extrusion under Structural Framing. i want to Replicate the Arch as it is, and i found Spline tool for that, it helps me to form Solid extrusion. but i want to make some extension over that spline using a different spline, and there comes the problem. two spline are not intersecting each other at a point, TAB key also not helping with this. Please guide me to draw this, what trick should be used. is it possible to draw that in Revit or need to be imported from AutoCad or something else.
i hereby attach the Snaps of what actually i wan to make and what are the issues
this is spline which makes the Arch, two spline with offset make a solid , and i can do it
the contionous spline is major arch and shorter one is onther which i want to intersect at point on Major Arch, but i am stuck over this
this is actually the Arch i am trying to make with a major arch and one which take its support to and is part of same Structure
