Spiral Stairs parameters
0 ANTWORTEN 0
Nachricht 1 von 1
mdeLB7ZX
154 Aufrufe, 0 Antworten
Hello everybody,
I've an issue when I create a spiral stair into revit.
I need to manage 3 different parameters : angle, riser distance and distance from central shaft to right support
Indeed, revit automatically create for me 24 steps of 14.63° angle each but i need to have a 15° angle per step. (full spiral stairs contain 360° of 24 steps)
When I modify the distance of the steps (I need 1600mm range),it has de wrong angle...And when I change the angle into 15°, the distance is scaled down from 1600mm to 1558mm.
How do I need to proceed to avoid this problem without create any new parametric family?
Many thanks in advance.
Martin
Tags (1)
0 ANTWORTEN 0
