I have followed many different avenues to change the family of a specialty equipment item into a generic model in order for it to be cut in section and elevation. When the new generic model is loaded back into the project a circular chain of references error is reported preventing the load of the component. The ID number provided by the error message doesn't exist in any window and is different every time I try to reload the family. The component is originally a manufacturer made family if that information is necessary.
Please help I have searched forums for 2 days trying to find an answer t this problem and don't want to end up deleting and redrawing a whole project for the reference error.
No need to fiddle with the existing Specialty Equipment family.
You should have just created an empty Generic model family and insert the Specialty Equipment family in. Nest parameters if necessary.
I'm not sure we have enough information to assist.
As a test...do you get the same error if you load the family into a new project started from an out of the box template?
Did you review warning in the family and project?
