Specialty Equipment family_visibility
2 ANTWORTEN 2
Nachricht 1 von 3
mairh_tsek
5185 Aufrufe, 2 Antworten
Hello all,
I received a Family_specialty equipment, in the V/G settings in the family are all the setting ON.
When I load the family in my project I cannot see the family neither in the floor plan nor in the 3D. Also in the section views it doen't display correctly.
I changed the family category in 'Casework' as the Specialty equipment are not cuttable. [ https://forums.autodesk.com/t5/revit-architecture-forum/specialty-equipment-family-won-t-section-cor...] But the result is the same!
I imported the family in a new revit project and it works perfectly!
So I compared the settings in the view template between my project and the new project.
I assigned exactly the same settings..but again in my project I am not able to see the family.
Is there someone that has a similar problem? Maybe any idea?
Thank you!
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: mairh_tsek
Upload the family and we can have a look what might be the issue.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
mairh_tsek
als Antwort auf: L.Maas
Thank you for your answer!
I found the reason.
In the V/G > Imported Categories > Imports in Families need to be turn on.
