Why is there no Spanish roof hatch pattern? How can I get it?
Solved by aRcHiTeCt.JM. Go to Solution.
Solved by Viveka_CD. Go to Solution.
... attached it is
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Hi @JKspace424
A quick tip is to model the roof as a mass and apply the Spanish tile component to it and apply the code (.pat file share by @aRcHiTeCt.JM_
Here's a video on modeling a Spanish Roof Tile
Hope that helps!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
.... you just need to convert your .pat file to a model by adding the following code infront of it,
.... see the revit.pat file for the explanation.
The name may contain any ASCII characters except for comma. They are shown in the list of
imported patterns. The comma and comment are optional. They are ignored by Revit. The header
may be followed by one of the following type directives:
;%TYPE=DRAFTING or
;%TYPE=MODEL
If neither directive is present, Revit assumes that it is a drafting pattern.
... and then
Manage - Additional Settings - Fill Patterns
Click Draftiong or Model depending on the type
Click New
Click Custom
Click Import and browse to Scott's .pat file
Now it's available to use anywhere
..... here are some .pat files, there are many spanish tiles to chose from, some are in the acad.pat files and have allready had the %TYPE=Model added to them.
aRcHiTeCt.JM
REVIT EXPERT ELITE
Hi @JKspace424
Please try the recommendations and let us know if this works for you!
Thank you!
Viveka CD
Try this - tiles scaled to space 9" horizontally:
; Written by HatchKit Team Edition Trial
; HatchKit Team Edition Trial (c)1990-2018 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2018-08-10
;-Time : 13:17:53
;-HatchKit Team Trial Version : 3.1.11.2768
;-HatchKit Team Trial Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*SpanishTile
;%TYPE=MODEL
-84.2894068625,5.4,6,5.9702231413,-0.597022314126,6.03,-84.4188805901
-95.7105931375,0.6,6,5.9702231413,0.597022314126,6.03,-84.4188805901
0,5.7,3,0,-6,3.6,-5.4
0,2.1,2.1,0,-6,1.8,-7.2
60.9453959009,0,0,130.249434142,0.291385758692,1.5444,-183.776942538
29.054604099,0.75,1.35,50.9925077738,-0.874157276169,1.5443,-60.229480846
-29.054604099,3.9,2.1,50.9925077738,0.874157276169,1.5443,-60.229480846
-60.9453959009,5.25,1.35,130.249434142,-0.291385758692,1.5443,-183.777042538
180,3.7641,7.5756,0,6,1.5282,-7.4718
-29.054604099,3.764,7.5754,50.9925077738,0.8741572761,1.2586,-60.515180846
-150.945395901,2.2359,7.5756,50.9925077738,-0.8741572761,1.2586,-60.515180846
-60.9453959009,4.8643,6.9643,130.249434142,-0.291385758464,1.1031,-184.218242538
-119.054604099,1.1357,6.9642,130.249434142,0.291385758464,1.1031,-184.218242538
0,0,6,0,-6,0.60012,-8.39988
180,6,0,0,6,0.6,-8.4
hth
Hugh Adamson
