Hi! I want to edit a window family to have an operable blue metal spandrel panel. I created a new extrusion with the metal material, but it is still not showing up in the model. Any help would be appreciated!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
I see it in the model. Assign the panel's geometry to a Material Parameter, reload into Project, and then, in the Project, associate that Material Parameter to a Project Material.
Thanks, I tried that originally, is there something I'm doing wrong?
Make it a Type Parameter, reload Family into Project, find the Family in the Project Browser, right-click on it and press Type Properties then then assign a Project Material to the Spandrel Material Parameter.
