Is there a way I can control the spacing between parallel lines of dimensions without manually spacing them evenly?
Please see the attached picture. I would like distance A and B to be the same.
Gelöst! Gehe zur Lösung
Gelöst von TripleM-Dev.net. Gehe zur Lösung
Hi @Anonymous
Dimension styles have a setting Snap Distance, when you move the dimension it will "snap" to it's nearest dimension,
- Michel
See also Dimension Line Snap Distance
