spaces and light counts
1 ANTWORT 1
Nachricht 1 von 2
377 Aufrufe, 1 Antwort
I am having Revit create spaces to do lighting takeoffs in each room.
However, the light families sit on top of the grid/ceiling plan and therefore outside of that space.
The space seems to stop at the finished ceiling.
Is it possible to extend all of the spaces to go past the ceiling plan to catch those lights?
1 ANTWORT 1
Nachricht 2 von 2
HVAC-Novice
als Antwort auf: Anonymous
You should host the lights to the ceiling. How else will the light get into the space assuming you don't have glass ceilings?
The light fixture calculation points need to be enabled and reach into the space to be counted for W/ft².
You could make the ceilings not "room bounding" to extend the space to the deck above.
Revit version: R2025.4
