Is there a way to get rid of these space bulges? Is there an adjustable tolerance in Revit?
Do a search on "sliver space". MEP imaginary clearance. Not sure if that is what your image indicates?
Hello
Unless elements are modelled precisely in revit, there is no settings as such, like tolerance in Revit.
I feel you can adjust in your Solibri settings while checking...
https://www.solibri.com/learn/using-the-space-validation-rule-to-ensure-model-accuracy
Thanks for your reply. I used Solibri just to let you see the problem. I want to import rooms into another third party application which can't manage these bulges.
