Space property y/n parameter controlling a tag family label
ADT267
ADT267
Space tag with a label showing an ‘A’ as below:
In the space properties, a y/n parameter that can be ticked. Ie asbestos present – yes or no.
If asbestos present = Yes – a big red ‘A’ appears in the tag.
If the asbestos present = No – The big red ‘A’ switches off.
I do not want to control by 'type.'
What version are you using?
ADT267
just updated to 2018
See below:
ADT267
Thank you, that worked a treat 🙂
Now need to learn how formulas work....
Edit: nevermind
I think I overworked the solution.  It should be much simpler.  See attached 2017 file.
