Space placing horizontal adjustment
2 ANTWORTEN 2
Nachricht 1 von 3
269 Aufrufe, 2 Antworten
Hallo,
I have another question about Revit. I was trying to make a Heating and Cooling Loads calculation and after analysing my surfaces I saw an airgap. I figured out how what causes this. But I can't re-design my space because I can only adjust it vertically and not horizontally.
The gap I want to fill is marked red in my attached image.
I hope this is possible, thanks in advance.
2 ANTWORTEN 2
Nachricht 2 von 3
constantin.stroescu
als Antwort auf: Anonymous
Try to draw a Space Separator Line at the border of your space to the bow window and then click to create an other Space that will be add to the existing one.
This problem appears usually when we have narrow spaces between building elements that are Room BoundingImage 1.png
Constantin Stroescu
Nachricht 3 von 3
als Antwort auf: constantin.stroescu
Thanks for you advice.
I can't make it work with the drawing of space separators.. I think because of the circular shaped borders.
Still the spaces to the left and to the right of the airgaps, from the attached image, needs to be filled.
(I know I can just place straight walls, but this will affect my results of the Heating and Cooling Loads calculation.)
