When I try to open my south elevation view it will open as my north elevation view. If I try to open north, east, and west elevation views they will open exactly the way they should, but the south elevation view will not. I have tried also turning off my computer and restarting it to see if that would fix it but it didn't. Does anyone know what is going on and how to fix it?
Weird, where is the location line of your south elevation? Check if direction and position are correct. Do so by clicking on your elevation marker, it will show you the location line.
Do you actually have an South Elevation Marker, or you you duplicate North and rename South?
If you have and South Marker in Plan View, select it and verify Cut Plane Line is in the correct location.
