Every once in a while I'll run into this issue where my eaves won't line up, (See attached Image). This doesn't make any sense to me as I don't adjust the "offset from roof base" value. All values are at 0 meaning that the Eaves should all be aligned with one another. If anyone is interested this example is just one singular roof footprint rather than the gable end being its own separate footprint. Usually making gable ends their own footprint will fix the issue, but I've had times where the gable ends would still not line up. This seems to be a glitch with Revit and I'm just wondering if anyone else experiences this issue and has a good reasoning for it?
Yes, but this doesn't correct the issue. That tool is essentially a quick way to align eaves that have different offset values. All of my Eaves already had an offset value of 0 so nothing really changes
