Can anyone help please? I am still learning Revit through TAFE and this is something that my teacher hasn't come across. We have been advised to show internal shadows via an Orthographic camera view, ie in a Section placing a camera to look straight down. Some of my walls do not show up when I try to do views on the First Floor. The walls have exactly the same attributes as other external walls which do show up, eg set -420mm, up to FF ceiling but then attached to top (roof).
i don't know what do you want but this is the way to make the plan with section without camera:
Hi @jennifergarrett
Thanks a lot for posting your question to the forums! Has the solution suggested by @azad.Nanva helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
There wasn’t a solution to the actual problem. Previously making sure the walls only went on the camera view level worked but all walls were set to the level. Deleted and reinstalled walls several times and it finally worked, don’t really know what the issue was.
