Some rooms not visible
muhammedbedir86
muhammedbedir86
Hi everyone
Some rooms in my Revit project are not visible.When I try to place room ı get an error like ''Multiple Rooms are in the same enclosed region. The correct area and perimeter will be assigned to one Room and the others will display "Redundant Room." You should separate the regions, delete the extra Rooms, or move them into different regions.''
But when I create a room schedule these romms dont appear on room schedule.I have checked rooms height and every other thing but couldnt figure out whrere are these rooms.
rxi.gg
Have you checked Phases? Maybe there are rooms in other phases or even in other sesign options if you have activated them.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
So, you are in a Plan View and other Rooms are displayed (e.g. you see References and/or Interior Fills and/or Tags), but when you go to place another Room, the "Multiple Rooms" message pops up?
Activate Reveal Hidden Elements (the lightbulb button on the VCB).  Maybe some are Hidden in View: by Element or Filter.
kanoferreira
My tip would be making a room schedule, a simple one, with simple parameters like name and area, sorting all phases of the project.
Then, the "unenclosed" rooms will appear on that table, you can select them, and delete them if you want it.
Hope it helps
If you have any finish floors above the Level, set them to Not bounding rooms.
afdigibran7ZBMWE
Community Visitor
Community Visitor
thanx, thats actually worked, ive been searching this for a whole hour
