'Some products are not installed' Revit 2024
PieterL_TM
PieterL_TM
Since the Autodesk helpdesk is of no use, I'll ask it here.
Does anyone know how to fix the issue 'Some products are not installed' for Revit 2024.
I'd like to add my setup.log file to this post, but I can't find it anywhere.
I believe I've tried 15 times already in various ways, I'm getting really desperate...
Replies (10)
jay_colcombe
Sounds like you are have a tough time unfortunately!
Obviously this is what Autodesk recommends an i would have to suggest trying these thing too.
"Installation complete. Some products failed to install." during installation of an Autodesk product
But i have had to run a few of these in the past and the only solution was to ensure the uninstall is done using the following;
Always use the Microsoft Uninstall Tool (it is called something different now) as this seems to clean up the messes left behind via Add/Remove method.  you may need to search around to find it as they push you down another route called troubleshooter now but it should be there somewhere via a google Search.
When reinstalling ALWAYS use the Browser Method as this gets around any connectivity issues, below is a great link and save me cutting and pasting
How to use the Browser Download method for Autodesk products (imaginit.com)
I really hope this solve your issues but if you are struggling try your reseller of the software or a local reseller they are always a great resource
Jay Colcombe
Autodesk Certified Instructor
PieterL_TM
 I tried both browser and download method again, and now I bump into error 4000 with both. There's some posts online about this, but they could not fix my issues
PieterL_TM
I still haven't been able to fix this, can someone please help. The official Autodesk helpdesk is of no use either...
RSomppi
Did you do the uninstall as suggested above?
PieterL_TM
What I found is that it was discontinued in 2018, I didn't find a first party alternative.
RSomppi
Did you try to uninstall and reinstall?
PieterL_TM
Yes, I think I'm up to 30 tries now...
for extra info:
When trying to install using a custom installation I get the error: โ€˜some products are not installedโ€™
When using the download method, I get the error 4000.
When using the install method, I also get the error 4000.
RSomppi
Does the install finish and have you tried opening Revit?
Do you know which products are not getting installed? Maybe you didn't select them or  even need them.
PieterL_TM
It doesn't finish with download and browser method, it goes to about 25% and then rolls back, uninstalling everything again.
With the custom install the installation does finish and everything is installed, exept for Revit itself...
RSomppi
I think you should be over in the Installation and Licensing forum. There are some helpful and intelligent people over there.
You can report your post to admins and ask them to move the thread.
