Some panels in this curtain system are slightly malformed (Please help)
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
spongebobdexter
354 Aufrufe, 5 Antworten
Tags (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: spongebobdexter
It's a warning so if you can live with how they look then just ignore.  Do you want to clean up the million intersection?
Nachricht 3 von 6
spongebobdexter
yes i want to clean up the million intersection, is there a way ?
Nachricht 4 von 6
spongebobdexter
als Antwort auf: ToanDN
Nachricht 5 von 6
There are several ways:
- adjust the curtain grids a bit so you don't have 3 way intersection.
- model the entire glazing as a window.
- use columns and beams for mullions.
- use a solid mass to cut mullions
Nachricht 6 von 6
spongebobdexter
problem solved ,thank you very much and god bless you
