Some lines in the file could not be used ERROR CSV TO REVIT FOR TOPOGRAPHY
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
aymane_azarou
796 Aufrufe, 12 Antworten
i dont know why this error prevent me to import my csv topography to revit 2025Capture d'écran 2024-08-15 142916.pngCapture d'écran 2024-08-15 142820.png
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: aymane_azarou
Your CSV only has 1 column. The CSV should be 3 columns. X, Y and Z.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-35F36FD6-9648-4008-B117-6D7771E5FA9B
Nachricht 3 von 13
aymane_azarou
als Antwort auf: barthbradley
actually i have 3 columns latitude longitude and altitude which are x y and z i dont know why you see one column in my excel there is 3 columnsCapture.PNG
Nachricht 4 von 13
The CSV you posted, and that I opened, does not have 3 columns.
Nachricht 5 von 13
Perhaps, this is your issue. Me and Revit see 1 column.
Nachricht 6 von 13
aymane_azarou
do you have any idea how i can fix this problem in excel because it appears to me 3 columns
Nachricht 7 von 13
Are you sure you posted the correct file. Try again.
Nachricht 8 von 13
aymane_azarou
yes i posted the right file i am sue
Nachricht 9 von 13
aymane_azarou
can you send me the file from your desktop . i will see if it gonna appear like what you see
Nachricht 10 von 13
Save it as a TXT File (comma separated) and use that TXT file to create TOPO.
Nachricht 11 von 13
This is the Toposolid I get from your data via txt file:
Nachricht 12 von 13
aymane_azarou
Nachricht 13 von 13
aymane_azarou
how you transform it into text file
