I cut a section and only so one level, not sure why other levels are invisible?
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Their 3D extents are not in the view range.
Select any visible level > right click and select All in project > right click and Maximize 3D Extent.
If you want to set your level to all sections & elevations, create a scopebox and set the level to that scopebox. Right now your levels are not showing because your section cut didn't cut through the 3d level extent. I would go to 3d and select the level and set the level to the scopebox.
@syman2000 wrote:If you want to set your level to all sections & elevations, create a scopebox and set the level to that scopebox. Right now your levels are not showing because your section cut didn't cut through the 3d level extent. I would go to 3d and select the level and set the level to the scopebox.
I want to explore your method for the situation when none of the level is visible.
I took over this model and it has been moved from far away to near the internal origin, perhaps that is the reason many things are messed up. I open the 3D view, and there are a couple of scope box there and when I click zoom fit, they became tiny spots in the window. I even can't see the building; and I don't see levels there when I zoom in.
Do you have CAD linked into the 3d? I would simply turn off CAD link first, zoom extend and then you would assign the level to scopebox.
Okay, I noticed there were total 4 scope boxes there but those tiny small ones are 3 scope boxes and there is another one not visible. I deleted the 3 scope boxes and zoom fit, I saw the one which is being used and the levels are there.
