I don't if this should be in AutoCAD or Revit forum but I am sure its an AutoCAD issue..
As you can see in the attachd image below there is a hatch or dotts appears in the linked CAD (circled in red) the photo is from Revit 3D model, anyway I purged everything and check everything in CAD but still gives me the lines, even when I do zoom to extent in CAD they don't appear.
I want to get rid of them. thanks
Gelöst! Gehe zur Lösung
Gelöst von EATREVITPOOPCAD. Gehe zur Lösung
I would start troubleshooting by copying & pasting the contents of the problematic CAD file to a new blank CAD file. Then re-link it See if the issue remains. If it does maybe these are floating points or points from blocks? inside the AutoCAD drawing you can enter command DDP and select a different visibility option for points to be able to see them easier
That's Point Style solved the issue completely, thank you.
I used 'PTYPE' command for 2022.
