Some families and types not appearing in 'purge unused'
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
1881 Aufrufe, 2 Antworten
1.JPG2.JPGYou can see them in the project browser but cant see then in purge unused. and these walls are not in the custom template i loaded.....also some walls i made in the custom template do not appear in the project.
2 ANTWORTEN 2
Nachricht 2 von 3
Ilic.Andrej
als Antwort auf: Anonymous
About purging: last type of stacked walls cant be deleted. This stacked wall you have contains wall types "Exterior - Brick on Mtl. Stud" and "Exterior - CMU on Mtl. Stud". Thus, those wall types cannot be deleted as well. The first thing I would check if whether "  9" BW    " is drawn somewhere. If not, simply right click the type and try to delete it.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 3
MostafaElashmawy
the marked families below can't be purged because walls is a system family so it always need 1 from each type (basic walls,curtain walls & stacked walls)
the stacked wall it self have two basic walls.
the 5th family which is 9" BW must be used some where in the project.
Right click on it and click select all instances in entire project then delete.1.JPG
Mostafa Elashmawy
