Hello Everybody,
i want ask you if someone have been face this issue before!
when I but a door on a wall "Plan" some families show the door's curve! and some of them does not! by the way all doors i take it from the original revit library "that came with revit".
3> how it's look like on plan.
2> how it's look like when i but the muse on it.
1> when i change the door to other family.
Thank you.
Some do have type properties to show door swings and so on.
no, it's not about Families Properties.
Cause when i draw a "Model Line" doesn't appear, also when i go to visual graphics, the lines is appears!!
Are you saying that when you draw a Model Line in Plan View of the Door Family, it doesn't show up in Plan View of the Project -- but it does show in 3D View?
Sounds like you have a Masking Region covering the Model Line in the Family. Masking Regions are draw at the Detail Plane of the View, so it would hide a Model Line drawn below it.
Here's a list of 33 other reasons why something may be missing in the view:
https://www.revitforum.org/tutorials-tips-tricks/441-cant-see-view-heres-33-reasons-maybe-why.html
-See if the double doors are offset from the Level?
-Is the door on the wrong workset?
Hi, are you sure that the door is not offset from the level?
Also, sometime I've seen that when the 2d lines for opening is on level 0 in the family and this family is inserted on a level that there is a floor finish higher than the level, it is going to mask the 2d opening lines.
I would have to get the revit file to look at it further...
Edit the family.
Click on the 2D you want to show. and go to edit.. visibility/graphics overrides
