Some areas are missing when exporting to ifc
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
JF.K
733 Aufrufe, 4 Antworten
Hi everyone,
We are having difficulties exporting certain areas into IFC. Some areas are missing although they are visible from the export source (Revit). I found the link  https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... claiming that it was solved in revit 2019 but its seems that we are having the same issue with Revit 2020.2
We tried:
  • workaround suggested by Autodesk (offset the problematic area boundaries so there was not overlapping area boundaries);
  • Make an export from the area plan itself floor plan and not 3D view;
We checked:
  • workset assignment;
  • area type;
  • Scopeboxes associated with 3D views;
Everything ended up with the same result. Specific area not being exported (see image below).
Are we missing something here?
Export options:
  • ifc 2x3 coordination view 2.0.
We are using:
  • Autodesk Revit 2020.2
  • Solibri Model Checker
Thank you in advance
4 ANTWORTEN 4
Nachricht 2 von 5
Rafal.Gaweda
als Antwort auf: JF.K
Hi @JF.K
Have You check it with \ without https://apps.autodesk.com/RVT/en/Detail/Index?id=8986482933300179260&appLang=en&os=Win64 ?
Could You be so kind and post or send me mentioned Revit file?
Rafal Gaweda
Nachricht 3 von 5
JF.K
als Antwort auf: Rafal.Gaweda
Hi @Rafal.Gaweda,
As you notice by my very late reply I was away from this forum for a while. Meanwhile the project went further and it seems that the issue disappeared. As far as I know all the rooms were able to be exported into IFC, but unfortunately I don't know what triggered and solved the problem.
The addin that you have suggested is not installed in our machines so it wasn't related with it.
I will let you know in the future if this happens again so we can properly track and tackle it
Thank you
Nachricht 4 von 5
indiana_j0nes
Perhaps it had to do with phasing ?
Kunal Tuljaram Gaidhankar
Nachricht 5 von 5
JF.K
als Antwort auf: indiana_j0nes
@indiana_j0nes we were modeling in the last phase (new). I am also assuming that no one was changing it since it is a new building with no existing elements.
