(solved) locked adaptive pointed not aligned in host family
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
heichan88
383 Aufrufe, 3 Antworten
(Solve) by lock the face of the joint point, (rather than the point) to , it solved now
I made a pair of joists, the upper joist slides at one end along the lower joist, the junction joint point are locked, but after nested, this junction are no longer fixed and then twisted.
There should be a  error of a simple operation but don't know what it is.
BTW can the warning of "off axis" be ignored and really have no any consequence right?
Please advice, Thanks
3 ANTWORTEN 3
Nachricht 2 von 4
heichan88
als Antwort auf: heichan88
(Solve) by lock the "face" of the joint point, (rather than the point its self ) to the host face, it solved now
Nachricht 3 von 4
That's not altogether true.  They can appear benign but impact performance - especially if you got alot of them.
Element Is Slightly Off Axis | Revit 2019 | Autodesk Knowledge Network
Nachricht 4 von 4
Yours is an adaptive so you don't need to be too worried about that warning.  If you don't want to see it, just drag a point a bit.
