Solution needed please-problem of floor finish material joining with the wall
1 ANTWORT 1
Nachricht 1 von 2
206 Aufrufe, 1 Antwort
I want to make ONLY the structural part of the floor to join the wall, But I cant seem to find solutions anywhere...
The floor Above Has the floor finish(ex. wood floors) joining in with the wall, while the bottom one connected properly without the finish joining into the wall. The option I could think is to seperate structural floors and finish floor but I think There must be a smart solution, since the bottom one worked properly..
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Oh, I found the solution..
You have to change the options of the material  at 'edit', from Structure > to thermal, finish, etc...
