Solution for heavy models
8 ANTWORTEN 8
Nachricht 1 von 9
Marcus.Isacsson
3214 Aufrufe, 8 Antworten
Hi fellas!
Does anyone know of a plugin or way to tell what's making a Revit model 'heavy'?
Some days ago our model all of a sudden started to behave "laggy".
8 ANTWORTEN 8
Nachricht 2 von 9
Sahay_R
als Antwort auf: Marcus.Isacsson
How big of a model? Anything above 300MB should be broken up into parts and linked.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 9
kadmonkee
no plug-ins
it is a matter of what is modeled and how it is modeled
the amount and types of families, how the families are created (level of Detail)
excessive errors or warning left unanswered
Linked files-Revit or AutoCAD
importing AutoCAD files then exploding the layers.
excessive views (sections for coordination)
also could be hardware or network infrastrucure.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 4 von 9
andybrack
als Antwort auf: kadmonkee
Yeah, start with the linked files.  Ask your team if somebody linked in new CAD files or Revit models. That could explain where a sudden change in behavior occurred, particularly if the CAD file is large (1-2MB). Also, in projects where CAD is mixed with the BIM model **gasp** there is a tendency to not clean out files that are no longer useful.  Some simple housecleaning will help that.
Sincerely,
Andy Brack
Nachricht 5 von 9
Marcus.Isacsson
als Antwort auf: Sahay_R
The file is 112 mb right now. Nice tip though, will keep in mind that 300 mb is a good limit.
Any way to calculate or anticipate the model size in early stages?
Nachricht 6 von 9
Marcus.Isacsson
@kadmonkee wrote:
no plug-ins
Yeah, I think that some of the families might've made it slower. We've modeled a bunch of wooden ribs that repeats along the facade.
Each family has a bunch of parameters (height, distance between them and so on).
I do think that there's a bunch of useful plug-ins though, a while ago I had use of this one:
Family Size reporter - Found some messed up over-detailed families for me
https://apps.autodesk.com/RVT/en/Detail/Index?id=3536917954730046399&appLang=en&os=Win64
Nachricht 7 von 9
Sahay_R
Large numbers of 3D furniture families that have a lot of swoopy-curvies, void geometry, are poison for a model. Revit does not like CAD files, especially if they are imported.
Rina Sahay
Nachricht 8 von 9
CAD content is the biggest hog, IME. Strip it out wherever possible and you'll be amazed.
Nachricht 9 von 9
It also depends on your hardware.  If you workstations are not entirely mediocre then you can certain handle files much larger than 300 MB.  It sounds like a threshold guideline from 5 years ago.
The more important point when breaking up a model is where to break it logically rather than just looking at the file sizes.  For example if your project is a shell-core then you can certainly break it to a shell file and a core file.
