Solid Panel Rail Baluster
PhilvK
Advisor Advisor
PhilvK
I'm working with a custom railing with solid panels. It appears that when you use a solid panel such as glass as one of the balusters in the pattern, you must work with the fixed width of the panel, correct? Is there a way to get the dolid panel 'baluster' width to flex with the length of the rail and other baluster spacings?
RDAOU
@PhilvK
Instead of mixing them in the Railing structure, Integrate the balusters with the panel.
Note: Patch Panels (Start/End sometimes might need to be custom panels)
PhilvK
By any chance do you have a quick example? I am not sure I follow you.
No.
You could use a Curtain Wall in place of the Railing though.
FWIW: Designing with Custom Railing Panels in Revit | Autodesk University
PhilvK
Thank you, I'll take a look
