Solid Fill / Transparency not working Revit 2017 over PCOIP
4 ANTWORTEN 4
Nachricht 1 von 5
vanboon_cei
879 Aufrufe, 4 Antworten
Not sure if this is another print/display issue over PCOIP....but
We are unable to make a transparent fill region/hatch. This worked fine in 2015.
In our properties-
 Background is set to transparent.
We also use the draworder to set this to the back.
The view is set to wireframe.
We've also tried setting the transparency for detail item to 25-50%. Still shows up solid.
Van
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: vanboon_cei
Hi @vanboon_cei
Can you try printing it with the print setting set to Raster instead of Vector?
Nachricht 3 von 5
vanboon_cei
als Antwort auf: Anonymous
We tried both of these as it was one of the possible solution in another post. Still no luck. It might be because we're running it over a VM/PCOIP. Still investigating.
Van Boon
Senior BIM Coordinator
Cupertino Electric, Inc.
1132 N 7th Street | San Jose CA 95112
T: 408 332-8917 | C: 408-332-8917
E-mail: Van_Boon@CEI.com
Twitter | Facebook | LinkedIn | CEI.com
[http://www.cei.com/sites/all/themes/cupertino/logo.png]
________________________________
We Deliver Power and Possibilities
Nachricht 4 von 5
Judy_S
Hi, vanboon_cei,
I'm Judy, a Revit specialist. I see you're having problems with solid fills and transparencies while working over PCOIP. Are you seeing this issue when working on the computer locally? If so, I'd like to see a journal from that Revit session to investigate further.
However, if you can't reproduce the problem when you're not using PCOIP, that would indicate the issue is the the Remote Desktop connection, not with the Revit software. Please see this page for more information from Microsoft about display issues when using Remote Desktop. While the article specifically addresses text issues, it also mentions that if additional issues are seen, you may need to create a support request.
Please let me know if this helps. If the problem occurs when NOT working over a remote connection, please send a journal file from a Revit session in which you open a file and recreate the problem. Journal files can be found at C:\Users\<username>\AppData\Local\Autodesk\Revit.
Thanks, and let me know what you find.
Best regards,
Judy Staicer
Judy.S
Product Support Specialist, AEC
Link Name | Link Name | Link Name | Link Name
Nachricht 5 von 5
Judy_S
Hi, vanboon_cei,
Just following up on last week's message to see if my post was helpful. Let me know if it was or if you need further help.
Thanks, and have a good day!
Judy Staicer
Judy.S
