Solid Fill for walls doesn't work even though cut patterns is set to solid fill
6 ANTWORTEN 6
Nachricht 1 von 7
ara.p93
421 Aufrufe, 6 Antworten
Hi I need help as this is very frustrating.
I'm trying to make my walls be solid black fill instead of outline.
I've set both Foreground and Background to Solid Fill Black but walls are still shown outlined.
It works fine in my other levels.
6 ANTWORTEN 6
Nachricht 2 von 7
se.ha
als Antwort auf: ara.p93
Hi @ara.p93,
looks like there is some transparency setting (stairs in wall, chair under table, ...) overriding the solid fill.
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Nachricht 3 von 7
Edit wall type, edit Coarse scale cut pattern.
Nachricht 4 von 7
That screenshot doesn't make a bit of sense to me.   Something's f*cked it.  Can you post the file?
...could be a corrupted view. Does duplicate view behave same way?
...AH! Maybe Phase Graphic Overrides are interfering.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-D...
Nachricht 5 von 7
Here's an example of what I think is happening.  See how Phase Overrides has hierarchy over VGOs by Category.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/Revit-D...
Nachricht 6 von 7
ara.p93
als Antwort auf: ToanDN
Tried coarse but didn't make a difference.
Nachricht 7 von 7
Did you try setting the View Phase Filter to "none"?  Betcha that resolves issue.  If so, some Category (e.g. Existing, Demo, New, Temporary) is overridden in the named Phase Filter the View is using.
