I am currently having a problem with .dwg links into a Revit reflected ceiling view.
I have a .dwg file with solid hatches linked into a Revit reflected ceiling view and from within Revit the view shows normally, The .dwg is sent to the back and all of my Revit MEP elements are visible.
But as soon as I print the layout, the .dwg file jumps to the front and masks my Revit MEP elements.
Possible solutions I have already tried:
The only way I can resolve this is to edit the .dwg to place all the solid hatches on its own layer and switching it off in the visibility graphics in the Revit view, But I do not want to make changes to the .dwg links.
I uploaded pics for reference
Does anybody know an alternative way or solution to this problem?
Thank you in advance for the help.
I cannot really find a great way in Revit to do this.
Placing the hatches on a new layer in the Cad file will actually be the best solution, then turn off the layer in Revit.
Thanks ToanDN,
I have tried this too, same happens, all that changes is now the pdf is pixelated.
