Hi All,
I need help, please.
I am not to able to understand why my model doesn't work.
I have created 4 solids, but I can't see the gaps.
Thank you so much.
Bye.
Antonio
Did you use the Cut tool in the project...to cut the host (and/or surrounding geometry) with the unattached voids in the family?
Hello @Anonymous
You family is a mess. To work this family I suggest that this family need to be separated into two families (elevator doors and Elevator machine/counter weight). For elevator door used the wall-base template and for elevator machine/counter weight used the floor base or face base template.
Thank you for your answer.
I have downloaded this file in internet.
Can I work without separated the solids?
Thanks.
Bye.
Antonio
I am not able to use Revit very well.
I'm working in the model that is in attachment on this.
Please, can you explain better?
Thank you so much.
Bye.
Antonio
