Solar Study Animation Broken Files
6 ANTWORTEN 6
Nachricht 1 von 7
Anonymous238
430 Aufrufe, 6 Antworten
I'm trying to export a solar study animation with just 600 frames at 1080p and the file is enormous (always 4gb or 4,194,356kb even if more than 600 frames which is odd). The file won't open because its "broken". What's going on?
6 ANTWORTEN 6
Nachricht 2 von 7
Anonymous238
als Antwort auf: Anonymous238
I have tried both uncompressed and microsoft windows 1, which are the only options when increasing the default resolution, and both won't open. If I make an animation with less frames like 50 it works fine. Revit 2025 can't handle exporting anything larger than a few frames?
Nachricht 3 von 7
2025.1 ?
Nachricht 4 von 7
Anonymous238
als Antwort auf: barthbradley
2025.02 and when I go to autodesk access it says revit is up to date yet I found a 2025.2 update... which I'm downloading now
Nachricht 5 von 7
Anonymous238
Updated to 2025.2 and still broken. Only can do 15 min intervals with under a hundred frames and uncompressed (windows compression looks like this). Anyone else experiencing this?
@Anonymous238 - this post has been edited due to Community Rules & Etiquette violation.
Nachricht 6 von 7
Export to individual frame images and convert them to video or gif.
Nachricht 7 von 7
Yep. 2025 is broken. Just ran some tests.
Open a Support Ticket on this through your autodesk.manage.com portal. Please let us know what they say if you wouldn't mind. Would be appreciated. Thanks.
Following...
