every time i try to create a day long solar study, revit will crash when i try to export into animation file. does anyone else have trouble in this area? why?
cheers
hi @leigh,
Just like that it sounds like your computer isn't powerful enough to calculate image by image.
But to be sure I would need more info...?
Do you get an error message?
Does it get unresponsive?
Does it crash?
What is your computer configuration like?
Happy to help if possible,
François
Francois-Gabriel Perraudin
BIM management and coaching
Hi Leigh,
Can you run the following test:
Open another project and try to run a solar study with the same parameters.
It will allow you to determin if the problem comes from your file or your software/computer.
Can you the give us the result?
Cheers,
François
