Solar analysis - even criteria for summer and winter
0 ANTWORTEN 0
Nachricht 1 von 1
304 Aufrufe, 0 Antworten
I have been going over and over my issue and trying to troubleshoot it and can't find any useful information through searching. Hopefully somebody can help...
So I have been making a solar analysis for a project I am working on. I want to show solar analysis for summer and winter using the same criteria / range. When i try to put values into legend manually, it just displays yellow. If i leave it as Auto the gradient colors display well, however winter range and summer range are different, which is understandable since the setting is min to max.
My issue is that if you look at the winter diagram it looks more illuminated than summer, when glancing at the legend and mass together. Clients would rarely look at the numbering.
My question is can I have same range for winter and summer so winter would display in more red/ blue hues and summer in orange yellow, while using the same legend.
I did try to reinstall the Insight plugin, with no difference. Attaching the 2 images for reference.
0 ANTWORTEN 0
