Soffit wall graphics
1 ANTWORT 1
Nachricht 1 von 2
drenL5229
217 Aufrufe, 1 Antwort
I am trying to hide the vertical overhead soffit wall dashed line from my view in RCP. I jumped on this project so didn't set it up initially. In the view template there doesn't seems to be anything on particular that controls the view of these walls. But, as you can see attached in the picture, they show with dashed line on the inside face. FYI The walls are above cut plane of course and the underlay is on.
I know I can do this with the Linework tool but that isn't the workaround I want.
I tried on a new project and these walls OOTB don't show up in RCPs unless they cut through the GWB or are flush.
Thank you!
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: drenL5229
Obviously, there is some override acting on the wall if it's shown as dashed. Here's a list of overrides that could be acting on it:
https://help.autodesk.com/view/RVTLT/2024/ENU/?guid=GUID-67D3D6DB-E78D-4711-B9C3-4D30F1C22205
