SO SICK OF COLUMNS NOT ATTACHING!!
4 ANTWORTEN 4
Nachricht 1 von 5
Base12
309 Aufrufe, 4 Antworten
How, still, years and years later in 2024 does this STILL NOT WORK?
[ The subject line of this post has been edited for clarity by @handjonathan Original: SO F'ING SICK OF COLUMNS NOT ATTACHING!!]
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: Base12
share this portion in a file so we can check?
Nachricht 3 von 5
Are you by chance trying to attach a nested column within a column family?
Nachricht 4 von 5
Base12
They're just basic, out of the box columns and beams.  Not nested or anything.  It does it to me all the time and regardless of the type of column/beam whenever I try to adjust either column or a beam within proximity of another one they go bonkers and will not behave.  Is there anyway to have "Disallow Join" be the default condition *before* beginning to draw a beam, etc? so that I don't have to dick around with manually disallowing every end of every beam from joining?  I get so frustrated with this stupid software being so fiddly to just do basic stuff.
Nachricht 5 von 5
SteveKStafford
Given your attached image, mind describing what steps you took/take to create them? Columns first, beams from column to column? Beam first then columns? Model in 3D view or plan view(s)?
Steve Stafford
