Old problem,
I have snapping on for endpoints - no angle snaps.
I draw a line but can't snap it to the end point because- well I don't ****ing know. Ortho? This happens all the time with tight angles. I just want to snap to the endpoint but no go.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
So what you are saying, is that you can't place a Angular Dimension period. Is that about the size of it? Nothing at all happens when you press Angular Dimension and pick line A and line B?
No.
I can't place a line exactly top of another slightly angled line. Like say if I wanted to create an area from my plotline.
Have you tried the pick line tool?
Doesn't work with property line.
Not the point.
Often have a line that just snaps to an angle or despite there being no angle snaps on. Happens with tight angles.
I think that you are going to have to provide an example of what you are trying to do.
@jfjacques wrote:No.
What's a "plotline"? Sounds like something to do with books or movies. If you mean Property Lines; the Area is automatically computed. Select the Property Line and look under its Instance Properties. The Property Line Area will report in a Tag and a Schedule. What more do you need?
