Snap/Ortho
Snap/Ortho
Message 1 of 17
Snap/Ortho
Althogh I love Revit's automatic Ortho, is there a way to turn them off?
Replies (16)
Message 2 of 17
type SO (snap off) while you are sketching any time you don't want automatic snaping. Or if you want it off all the time under setting snaps you have the same type check box that acad has for the diff. snap options.
Message 3 of 17
How about the ortho?
Message 4 of 17
there really isn't an 'ortho'....you are free to move in any direction.
Some objects are 'constrained' to a plane, which can be toggled off by
clciking off the Constrain checkbox in the Options Bar while using Move or
Copy.
wrote in message news:4815054@discussion.autodesk.com...
Message 5 of 17
Great, thanks for the reply
Message 6 of 17
Hi that's gr8,
however, I'm trying to teach myself how to use revit and complete my 3rd design studio project for 3rd yr architecture and want to know what and where the OPTIONS BAR is coz I can't find it and I'm about to screeeeeeeeam!!
thnx a mil if u can help,
regards,
Lizzy
Message 7 of 17
Alfredo_Medina
The Options Bar that Scott is referring to is in between the ribbon and the view. It remains empty when no command is active. As soon as you activate one, such as Wall, or Move, etc., the options bar fills with pop up menus, check boxes, etc, relevant to the command that is active.
Alfredo Medina
info@planta1.com
Message 8 of 17
I think I read somewhere that the Options Bar has been discontinued in
2011, and incorporated into the Properties window (palette?).
> Alfredo Medina
> info@planta1.com
Anthony Mason
http://dailyoccurrence.wordpress.com/
Message 9 of 17
Options Bar still exists in Revit 2011
"Anthony Mason" wrote in message
news:6361628@discussion.autodesk.com...
> Alfredo Medina
> info@planta1.com
Anthony Mason
Message 10 of 17
Alfredo_Medina
Anthony,
I don't know yet. I am waiting for my box to arrive in some weeks...
Alfredo
Message 11 of 17
As Scott said the options bar still exists in 2011 but as in 2010 things are
moving off the options bar and finding new homes in other parts of the
interface, but some still remain.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
"Scott D Davis (Autodesk)" wrote in message
news:6361810@discussion.autodesk.com...
> Alfredo Medina
> info@planta1.com
Anthony Mason
Message 12 of 17
Ignor all info previous.  Goto  MANAGE, SNAPS (it looks like a unside down magnet).
Enjoy.
Message 13 of 17
Re Ortho - There is an ortho in Revit 2011.
It appears on th eoptions bar as "Constraints".
Will Johnson
University of Wolverhampton (UK)
3rd Year BSc Student
Message 14 of 17
This is stupid.  2 pages of forum talk to find a solution to Ortho?  Revit sucks.  I really don't care if "it's the best thing out there".  It sucks.  It's stupid.  Autodesk wants us to pick up their slack at every turn.  Why do they even have a help section?  Whatever.  I'm done for the day.  Good luck everyone and happy new year to everyone but the Revit team at Autodesk.
Message 15 of 17
mikebZP76Q
This thread is nearly old enough to get a driver's license, and still no real solution has been provided. The question of ortho snap clearly evokes the frustrating and inexcusable flaw in Revit where certain angles just can't be drawn. I have a situation where I need draw a diagonal line in elevation whose end point is 6 1/8" higher than its beginning point. So imagine a right angle triangle where the long horiz edge is 50' and the vertical edge is 6 1/8". It is absolutely insane that Revit 2022 CAN'T DRAW THIS HYPOTENUSE. When I try it snaps about 1' above, or a few  inches below, but never to the point where I need it to snap. And if an Autodesk gaslighter replies 'well why are you trying to draw it at those dimensions?' I think my head might explode.
Message 16 of 17
mhiserZFHXS
This can absolutely be done, and in multiple ways. Is this line in isolation, or is it in reference to other elements? The answer to that would determine the easiest way to do it.
Message 17 of 17
RSomppi
I stopped using Ortho in AutoCAD was before I even knew Revit was a thing. Polar Tracking and OSnap tracking are like Ortho on steroids and Revit has the equivalent to both.
Good luck with that.
