Snap End Point is not working as it should.
3 ANTWORTEN 3
Nachricht 1 von 4
cmiyares.mcsal
189 Aufrufe, 3 Antworten
Hi All,
I'm having this issue with a project; when I use the command move and try to snap 'Endpoints' to the corner of the column, the snap icon is a bit off.
Do you have any ideas why this is happening?
Thank you in advance.
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: cmiyares.mcsal
Is your model far away from the origin point?
Nachricht 3 von 4
cmiyares.mcsal
als Antwort auf: syman2000
Yes, about 2200 feet. Thanks
Nachricht 4 von 4
syman2000
Typically the further the project is away from Revit origin, the graphic fidelity will take a hit. This is why snap behave weirdly and won't snap as intended.
