Looking for a Revit 3D residential type small pendant light of the types that are installed in ceilings over a kitchen high counter where people sit on hight stools to eat (possible each stool location will have one of these lights, so that is why the light cannot have a very large diameter).
Did some search in Seek, but the pendant lights there are 26" wide, 36" wide, etc., which are very large for small kitchens.
This is for residential use, and will like it to be able to be seen also in 3D (in addition to 2D since it will also be seen in the 2D Reflected Ceiling Plan), since it is for a Kitchen rendering where the hight counter is seen as a focus.
If any one has one or two styles (i.e., families) that can be shared, or the link provided, will be appreciated.
Thanks in advance.
DISCLAIMER: The following are based on a Google search. I have not downloaded, let alone used any of the content on the sites listed here.
10" wide x 24" high:
http://seek.autodesk.com/product/latest/agg/visalighting/Visa-Lighting/17577
Many manufacturers offer Revit models; not sure exactly what look you want, or whether any of these are readily available where you are.
Focal Point [Fusion and Groove B - G are pendants]
http://www.focalpointlights.com/resources/revit-files
Tech Lighting [Hudson and Mullberry pendants]
http://techlighting.com/Downloads#revit
There were random fixtures from other manufacturers in my search. Most seemed more commercial that residential to me. You may need to create your own if no one else has content to share or better source links.
Sounds like a perfect opportunity to learn some basics of family creation... ![]()
Do you have a picture of what you want?
Thanks to those who responded previously.
The attached rendering study shows pendants conveniently obtained from the program, which visually work to scale and proportion, however, their design is not quite attractive.
If anyone has a more attractive style for this type of application that can be shared or provided with a link for unobstructed public use, please advise.
Thanks in advance.
it really would help if you could post a picture of what you want rather than what you've got / don't want.... ![]()
It's possible to build most things.
Are you looking for something like this?
https://forums.autodesk.com/t5/revit-architecture-forum/place-light-in-kitchen/m-p/8388434
nearly 5 years on if he hasn't got something by now I'd probably give up... ![]()
Haha..Yes, but, I read the question twice and did't understand so thought to ask.
